I have thousands of Karaoke files in zip format, but when I click on the folders, they are not showing. If i go the the folder and extract the zip file, then it will play and recognise the cd+g format. Any ideas please ?
geposted Sun 11 May 14 @ 12:26 pm
in options, search for "zip" .. see if 'showZipKaraoke' is set to "yes"
geposted Sun 11 May 14 @ 12:29 pm
Open settings, check the "Show Advanced Options" checkbox and then search for zip.
Set the option "showzipkaraoke" to "yes"
Thank you......:-)
geposted Sun 11 May 14 @ 12:36 pm
Virtual dj 8 zip file open password sent my Gmail
geposted Sun 20 Mar 16 @ 7:30 am
virtual dj 8 have a zip i dnt know the password
geposted Tue 14 Jun 16 @ 11:53 am
I have the virtual dj 8 pro to infinity zip but I dont have the password. How can I get the password. Or please send me the password.
geposted Mon 11 Jul 16 @ 4:23 am
$$$$$did you buy the software here??????
geposted Mon 11 Jul 16 @ 5:08 am
guiz can u pliz send me virtual Dj atomix password zipped
geposted Wed 01 Feb 17 @ 12:23 am
I have virtual Dj 8 pro, but I don't have a password,how can get the password or send to my Gmail.
geposted Wed 22 Aug 18 @ 1:15 am
the only option here is to visit this link -> https://www.virtualdj.com/buy/index.html
geposted Wed 22 Aug 18 @ 9:30 am
