Done this twice already :/ everything will be going fine and then vdj 8 will crash, and relaunch itself, but at the exact point where it crashed, however it no longer would be going thru my decks soundcard (ddj sx) and would be playing thru the laptop built in speakers... Osx10.9.2
geposted Sun 11 May 14 @ 2:16 pm
Same problem here, macbook pro 13'", core i5 -2.5 Ghz, 16 GB ram, OSX 10.9.2. Vdj crash and restart a lot of time ramdomly without any connected device.
geposted Mon 12 May 14 @ 5:54 pm
Do you guys get this issue too? http://www.virtualdj.com/forums/187349/VirtualDJ_8_Pre-Release_Forum/Mac_freezes_when_trying_to_close_VDJ.html
geposted Mon 12 May 14 @ 5:56 pm
I detect that the crashes happen when I play a songs that content accent in the title or in the artist name, example: morenamía" , silverío, guarajé... Or words that content ñ, like niña, señor .... Vdj crash or not respond.
geposted Tue 13 May 14 @ 11:58 am
Yes i got this too
geposted Tue 13 May 14 @ 1:34 pm
+1
geposted Tue 13 May 14 @ 2:03 pm
Can you still repoduce this issue with the actual build?
geposted Wed 14 May 14 @ 5:30 am
Still crash and restart in VDJ 8 (1742.644).
I use Macbook Pro13" , Core i5 2,5, 16GB ram, HD4000, 750 -7200 rpm hard drive under Mavericks.
geposted Thu 15 May 14 @ 11:03 am
MBP 8.1 13 "OSX 10.9.2 2.3 GHz Intel Core i5 / 4 GB Ram
VDJ 8 B1752.626
if VDJ runs only with the internal HDD now I have found no problems, but I close my WD 2TB (My Passport 071D) with Firewire, then he gets hot and then stops responding or freezes ... (must be the process manually kill)
I do not get a crash report :(
VDJ 8 B1752.626
geposted Thu 15 May 14 @ 1:31 pm
I GET THIS ALSO..DO YOU HAVE A FIX YET?
geposted Mon 07 Jul 14 @ 11:40 pm
DOES ANYONE HAVE A FIX FOR THIS PROBLEM? PLS HELP....
geposted Mon 07 Jul 14 @ 11:41 pm
