Hi there,
Scratching and backspins are much louder than normal playback. Is there an option that affects it? SvenDeKay gave me a hint that I should disable the limiter for testing, but its always on?! From now on the limiter is not optional?
Regards, Christian
Regards, Christian
geposted Sun 11 May 14 @ 2:59 pm
Yes. The limiter is always on. It activates to prevent distortion on digital signal path. So even if you were able to disable it, it wouldn't be a good idea...
geposted Sun 11 May 14 @ 3:43 pm
Backspins I find are always louder anyways, its not just a V8 thing. In a real record will produce a louder sound if you back spin, the same when it comes to scratching in general I find. It just doesn't seen unusually loud to me.
geposted Sun 11 May 14 @ 3:50 pm
