Hi there,
the VMS 4.1 makes no sound with ADJ ASIO as soundcard, same settings work on VDJ 7. If I use VMS 4.1 as soundcard (not ASIO) it works.
Are there some general changes in the way controller sound cards are used?
Regards, Christian
Regards, Christian
geposted Sun 11 May 14 @ 3:04 pm
Are you using the Audio Setup that the button you see on the top offers ? Do you use any custom mapper or definition ? Could you please try to select the factory default mapper from the Controllers tab ?
geposted Sun 11 May 14 @ 3:14 pm
my program was lost i reloaded it and now i get deck 2 sound out of deck 1 out put... and no sound from deck 1 at all.
what i doing wrong.
what i doing wrong.
geposted Tue 13 May 14 @ 7:18 pm
Post a screenshot of your Audio config screen and we'll have a look.
geposted Tue 13 May 14 @ 7:20 pm
this related post may help:
General_Discussion/vms2_gain_control_going_up_and_down_on_its_own___help_asap_pleeease.html
geposted Tue 13 May 14 @ 7:29 pm
problem with my vms4.1 using vdj8, all lights become lit, when i turn on my system and never go off, i load music in the right deck and play but to hear it i have to move the cross fadder to the left just to hear music, when it loaded in the right. i noted this problem when you guys do updates!
geposted Sun 14 Sep 14 @ 10:07 pm
