Topic: How to adjust Jogwheel sensitivity and Tempo slider (pitch slider)
I am looking to be able to adjust the sensitivity in both the jogwjeel and tempo slider....version 8 seems confusing to me
geposted Sun 11 May 14 @ 3:22 pm
in vdj option settings, just search for "sensitivity" ;)
PS : needs "show advanced options checked in he top right corner to show all settings
Pitchslider you probably mean range.. search for "pitch range" in options and set to say 50 or even 100 for full range
Im looking for the same solution, thing is the bend with the jog wile the song is playing is too strong... on the 7.4 the setting i had for the JogSensitivityBend was 128, how do i set up that in the version 8... numbers are different 0.100000
cool, DJ in Norway, i did get it worked out....so to Frochocr....i searched jogwheel and 3 things came up....for the top one "Scrtch" i did all zero's....the bottom one the "bend" i set mine to .010 and it is perfect to spin it a bit like CDJ's :)....hoped this helped :)
yes it helped, thanx buddy.
I was having same issue - this post helped with the actual parameters suggestion such as 0.01xx !! :-)
