VDJ 8 is awesome, but there is something annoying...
My laptop resolution is 1366... And vdj skin is 1920 or something like that. So, I had to zoom in or increase the browser size, okay i fixed first problem... Now second thing is that Im seeing some texts or letters from buttons are kind of small. I think thats due to de resolution of the skin... Now the really annoying thing here, is when I reduce or shorten anything in the browser area, it becomes really tiny. In the previous version(VDJ 7), when you shorten something, it was cut but it kept the same size. In this new version, it becomes all tiny and I am not able to read larger texts.
So can anybody provide me 1366 skin? please.
EDITED FOR LANGUAGE
EDITED FOR LANGUAGE
geposted Sun 11 May 14 @ 6:25 pm
You don't need a 1366 skin.
The browser issue can be fixed:
config -> options -> select advanced checkbox -> search browsertextfit
change to 'fixed' or 'scroll'
The text buttons - could be fixed by a custom skin - or you could edit the text size in the default skin. I understand that this isn't the best solution. But would work for the time being,
geposted Sun 11 May 14 @ 6:31 pm
Thank you so much, you really helped me. Thanks a lot. Problem solved.
geposted Sun 11 May 14 @ 7:03 pm
No problem
geposted Sun 11 May 14 @ 7:04 pm
