Topic: Track Cleaner - (Snap to Beat)
NAWTBOYPRO InfinityMember since 2003
Messing around with Track Cleaner and I love it but know there is room for improvement.
Can you make it so it snaps to the beat as you are dragging the area you would like to remove?
Also Once I save my new track with edits do I need to keep the Original for the edit to work or can I delete it?
geposted Sun 11 May 14 @ 7:45 pm
Yes you need to keep the original.
The edit is an XML file with your edit information inside it. It tell VDJ where to cut or alter the track as you selected.
geposted Sun 11 May 14 @ 7:47 pm
You need to keep the original file.
geposted Sun 11 May 14 @ 7:48 pm
No, you cant delete it. Editor creates a vdjedit file, but its not the actual file, its kind of a shortcut with "instructions" how to handle the track.
geposted Sun 11 May 14 @ 7:49 pm
OK Thanks for the quick replies
any thoughts on the snap to beat functionality in the cleaner?
geposted Sun 11 May 14 @ 7:52 pm
Fair request. Thats all we can say for now. I am sure that Delepment Team will add that to their toDo List. For now, you can still zoom-in to the beatgrid and be as more precise as possible.
geposted Sun 11 May 14 @ 7:57 pm
