Hey Guys!
Just a quick question - How do I use ch3 and 4 on Pioneer DDJ-SR?
In addition, why the volumeter leds are not working too?
Im on MAC OS-X Mavericks
Your inputs will be highly appreciated
Thanks in advance.
Gab
Thanks in advance.
Gab
geposted Sun 11 May 14 @ 10:59 pm
up
geposted Mon 12 May 14 @ 10:37 am
dev team/admins/anyone?
I'm dead serious above the 4 channel set-up and I can't utilise this feature using the Pioneer DDJ SR - is there a fix on this?
I've already installed the SR Controller plugin for Mac but still in vain. Only Channels 1 & 2 are working OK. Loading tracks on 3 & 4 is no good as it loads on 1 & 2.
If this is still a work in progress, please let know.
Thanks.
Gab
Thanks.
Gab
geposted Tue 13 May 14 @ 11:33 am
Here's my MAC info;
![](/image/40360/135407/Screen Shot 2014-05-15 at 6.25.47 PM.png)
geposted Thu 15 May 14 @ 5:30 am
Works fine here.
Nothing is really changed in version 8 for this controller, however, please make sure that you dont have any definition or mapping files in /VirtualDJ/Devices and /VirtualDJ/Mappers folders.
FYI. the VU meters will show nothing if set on MASTER position and you have selected a different sound card for Master Output.
If the DDJ-SR is selected as Master Output (default Audio Setup_, then it will show the Master Level on the MASTER position, and on the CH12 position it will show the level of the Left and right decks.
LOAD works fine too for all 4 decks.
Please test again and report back in details if you still have issues.
geposted Fri 16 May 14 @ 2:24 am
djdad, thanks. i'll explore that and report back later.
fyi, phantom had already advised me re this on this thread - http://www.virtualdj.com/forums/187771/VirtualDJ_8_Pre-Release_Forum/Controller_not_working_as_expected___PLEASE_READ___.html?page=2
PhantomDeejay wrote :
Confirmed. There's an issue in HID on MAC. It will be fixed with next update.
PhiDJ wrote :
Hi Phantom,
Had tried it unfortunately, still no changes on response of the Pioneer DDJ-SR controller.
[IMAGE1][IMAGE2]
I'm on Mac OS-X Mavericks
[IMAGE3]
[IMAGE1][IMAGE2]
[IMAGE3]
geposted Fri 16 May 14 @ 2:40 am
DDJ-SR is not a HID Device , its a MIDI one, so most likely Phantom was replying to something/someone else.
It works fine here even with the build you have.
geposted Fri 16 May 14 @ 3:02 am
will remove everything and fresh install 8 now..will keep you posted, djdad. Thanks!
geposted Fri 16 May 14 @ 4:48 am
same issue after the reinstallation of 8, djdad.
fyi
the audio setting:
![](/image/83647/135583/Screen Shot 2014-05-16 at 6.18.21 PM.png)
SR FW ver
![](/image/14056/135585/Screen Shot 2014-05-16 at 6.31.24 PM.png)
btw, i got this message while reapplying the mapper for SR
![](/image/22672/135584/Screen Shot 2014-05-16 at 6.24.42 PM.png)
pls do let me know if i missed anything on the set-up.
Gab
fyi
the audio setting:
SR FW ver
Gab
geposted Fri 16 May 14 @ 5:33 am
Update:
mapper for SR has been installed successfully by adding a device folder on VDJ directory.
But, 4 channel function remains a mystery.
@dj dad, you said SR works fine with your machine, right? could you pls send some tips and tricks for me to play around with? maybe mine just need a bit of tweaking?
I'd greatly appreciate it.
Gab
Gab
geposted Tue 20 May 14 @ 11:50 am
There is no need to install any mappers or files for the DDJ-SR. But no matter what files you have in Mappers folder or devices folder, you should still be able to use the default factory ones.
So in the CONTROLLERs tab you should be able to see the DDJ-SR on the left side, and if you click (select) that, you should get at least the factory default Mapping option from the right sided list.
Once you choose that, you should be OK.
If you still have issues please report.
Btw, whats wrong with 4 Channel function ? (mystery) ? Keep in mind that the unit needs to be in the "Other DJ software" mode , not Serato) - read the manual on how to switch to that
geposted Tue 20 May 14 @ 12:42 pm
Got it djdad. Finally! :)
All 4 channels on SR are now working A!OK!
As per manual, just have to change this baby..
![](/image/10199/136483/Screen Shot 2014-05-22 at 10.11.39 PM.png)
Thanks very much for continual help - I appreciate it!
geposted Thu 22 May 14 @ 9:16 am
up
geposted Thu 22 May 14 @ 11:07 am
Mods, kindly update subj with text "fixed"
Tnx
Tnx
geposted Thu 22 May 14 @ 6:08 pm
Well that is not the solution of course, as you have actually disabled the version 8 default definitions, so your device worked with the files that you had in Devices folder, which are from version 7.
I am really curious on what other things you have in those folders (Devices/Mappers), as the unit works fine here with the built-in files. If you get a chance to try again, put that setting back to No, and try with the default factory mapping.
geposted Thu 22 May 14 @ 7:23 pm
i see.. I'll provide screenshots later, djdad.
geposted Fri 23 May 14 @ 7:17 am
As requested:
![](/image/20663/136722/Screen Shot 2014-05-24 at 2.58.35 AM.png)
![](/image/53712/136723/Screen Shot 2014-05-24 at 2.58.54 AM.png)
Restore the default setting - now ch 3 & 4 were back to old issue..
![](/image/51601/136724/Screen Shot 2014-05-24 at 3.09.38 AM.png)
Here's the problem when loading track to ch4 while deck 2 is playing.
![](/image/22918/136726/Screen Shot 2014-05-24 at 3.13.16 AM.png)
My sound card setting for your reference:
![](/image/83722/136728/Screen Shot 2014-05-24 at 3.15.59 AM.png)
geposted Fri 23 May 14 @ 2:19 pm
up
geposted Tue 27 May 14 @ 10:32 am
I really cant reproduce your issue.
In CONFIG->Controllers tab , do you see the device detected properly as PIONEER DDJ-SR and next to that, factory default in Mappings ?
Do you have the unit in the "Other DJ application mode" ?
When you switch decks on either left or right side, do you see the LOAD buttons change color from Red to Orange ?
In Applications-->Utilities-->Audio MIDI Setup, choose view MIDI Window from the top Window menu bar. Is the unit detected there as "PIONEER DDJ-SR" ? If not, double-click on the device and rename it as previously
geposted Tue 27 May 14 @ 11:20 am
When you switch decks on either left or right side, do you see the LOAD buttons change color from Red to Orange?
Yes, I confirm on this.
djdad wrote :
Please excuse my ignorance but I can't find this part in the manual. Appreciate if you can provide instruction/screenshot as to where this can be triggered? Do you have the unit in the "Other DJ application mode" ?
I'll try this tonight then report back.
Thanks again for your help DjDad.
geposted Wed 28 May 14 @ 3:17 am
