Topic: Denon DN-S1200 mapping issues with V8!
dydy1PRO InfinityMember since 2006
Denon DN-S1200 mapping, was not imported to V8. Is there any plan in the near future to make compatible with V8?
geposted Mon 12 May 14 @ 7:52 am
They are no longer supported with v8.
Maybe a user will write a mapping. But don't know if it will run with v8.
Is there a way to import your old mapping? You guys should still make all these players compatible with the software.
geposted Mon 12 May 14 @ 7:54 am
The 1200 is listed in the available devices, so should be supported AFAIK.
geposted Mon 12 May 14 @ 7:56 am
That is great news!
Any ETA on when this update might be available?
geposted Mon 12 May 14 @ 7:59 am
It's listed in the current build - if you right click in the mapper devices window, you can show all controllers ;)
geposted Mon 12 May 14 @ 8:02 am
SBDJ, I see it in the list of all the controller but V8 is giving a message saying they are not connected when they are!
geposted Mon 12 May 14 @ 8:11 am
OK, I got my old Denon DN-S1200s working now with VTDJ 8! The procedure was as such: In Mac, go to Document folder and open the Mapper folder and copy which ever mapper you are trying to use with the VTDJ 8 and go to Device folder and paste the old mapper there. Reopen VTDJ 8 and voila VTDJ 8 will now recognize your Denon DN-S1200s. Not all the buttons are working at this point because of many changes with the new VTDJ 8, but a few still works like on VTDJ 7.
geposted Thu 15 May 14 @ 11:32 pm
I still have a problem using Mac with VTDJ 8 and Denon DN-S1200s. Deck 1 is shown on the Denon Display as deck 2 vs! Is there a way to fix this? Also the titles of the songs on the decks no longer show. I suppose Denon support need to tell us what is the new scripts for those functions.
geposted Thu 15 May 14 @ 11:34 pm
