I have a bunch of Crates in my Serato DJ that I want to import into VDJ 8, they show up in the VDJ 7 Pro but I can't figure out why or how to get them into VDJ 8.
Help.
Help.
geposted Mon 12 May 14 @ 10:31 am
If Serato folder is not in the default location then you will need to set it.
Config->options-> advanced ->search 'Serato'
Ensure this location is correct.
geposted Mon 12 May 14 @ 10:35 am
Went to it and clicked set as default still not showing up.
geposted Mon 12 May 14 @ 10:57 am
Above the browser font size buttons is a toggle button.
In there make sure crates are selected:
![](/image/17584/134831/2014-05-12_1711.png)
geposted Mon 12 May 14 @ 11:12 am
The Crate is selected, still not showing up.
geposted Mon 12 May 14 @ 1:20 pm
in my case the Serato folder in music must be _Serato_, no ScratchLIVE
geposted Mon 12 May 14 @ 1:59 pm
When I try all that shows is an icon that says crates but nothing is in them.
geposted Mon 12 May 14 @ 3:27 pm
