Hi VDJ Team,
Thank you for VDJ8 its great so far.
It seems that 24 bit audio files play at a very low volume.
Cheers
Cheers
geposted Mon 12 May 14 @ 10:40 am
Would it be possible for you to send one of these 24-bit audio files you tried to use to me so I can check why the volume is low?
Thanks
Thanks
geposted Mon 12 May 14 @ 10:51 am
Download for free from here:
http://www.2l.no/hires/index.html
I use these for testing and customer demonstrations.
Cheers
Cheers
geposted Mon 12 May 14 @ 11:49 am
I would expect classical music like that to be much quieter than pop music and dance anyway. Much wider dynamic range with lots of soft parts.
Is there any particular one you tried?
geposted Mon 12 May 14 @ 11:52 am
Unfortunately the sample that I use is at home I am currently at the day gig. The sample I use is more modern pop and clips the meters in VDJ7 and is only 20% as loud in VDJ8.
for now try these classical clips in VDJ7 and then VDJ8 and you should hear/see what I mean.
geposted Mon 12 May 14 @ 1:13 pm
