Topic: Effects not compatible with 8
Hello, some of the effects are showing as non compatible. Ie brake, backspin and flip n double. The others are working.
Any ideas?
Thanks chris
geposted Mon 12 May 14 @ 12:21 pm
Those effects have to be rewritten by the developer.
No way to change this behaviour yourself.
geposted Mon 12 May 14 @ 12:22 pm
Ok I see so those effects are not available at the min?
Another question regarding video. Is there a way to turn the virtual Dj logo off the bottom of the screens?
geposted Mon 12 May 14 @ 12:53 pm
Jason KPRO InfinityMember since 2007
Options click advanced type in the search field what your looking for. In this case logo. You can even add your logo instead.
geposted Mon 12 May 14 @ 12:56 pm
prasanfPRO InfinityMember since 2011
Yes you can turn off the logo. Its under video options I think. You have to check the box that says "show advanced options". Cool thing is that now you can choose your own logo as well if you want.
Also the Syphon effect is not compatible with VDJ 8
geposted Mon 12 May 14 @ 2:03 pm
I have already ported Syphon to v8 (and written a PC equivalent too) and will upload it later today.
geposted Mon 12 May 14 @ 2:33 pm
some effect like "loop out " isn't clean , "slicer" no difference, le "long break" we had boutton who don't active
geposted Thu 15 May 14 @ 5:45 am
Now that's interesting!
What PC software will it allow use with? I don't suppose you heard any more from Arkaos?
geposted Thu 15 May 14 @ 5:56 am
vjmundyPRO InfinityMember since 2014
Please +1
geposted Thu 22 May 14 @ 12:36 am
geposted Thu 22 May 14 @ 9:22 am
