dad the second I changed what you told me everything worked... Plus I had to recode too.
geposted Thu 22 May 14 @ 12:24 am
<?xml version="1.0" encoding="UTF-8"?>
<device name="Akai APC20" author="Michael Stretch" type="MIDI" sysexid="F07E??0602477B001900010000007F7F7F7F004B0201020002000205010000010400F7" drivername="Akai APC20" drivernameout="Akai APC20">
I also has one for the 40 as im running a apc 80
geposted Thu 22 May 14 @ 12:29 am
im going to try this tonight on my apc40 but curious to know if this is the same process for KorgNano Kontrol as well?
geposted Thu 22 May 14 @ 11:06 am
all i had to do was change this value one time after I opened VDJ8 and everything worked!
<debugLogMidi>yes</debugLogMidi>
I closed it and set it back to
<debugLogMidi>no</debugLogMidi>
and everything is working as normal!
Thanks DjDad
Thanks DjDad
geposted Mon 26 May 14 @ 6:10 pm
Awesome Help from the staff.. This was an option in earlier beta version and replaced by "CreateMidiLog"
If someone asked you to enable it find the option in settings - > options, advanced (search)
then turn it on and we are kicking it..
geposted Wed 28 May 14 @ 7:17 pm
