Hello,
I have a problem with my sound card.
I have a very loud noise in the left speaker. (PCHHHHHHHHHHH)
In the right thing.
I have no problem with VirtualDJ 7
Name VIA High Definition Audio
Manufacturer VIA Technologies, Inc.
OK status
ID Device Plug-and-Play
HDAUDIO \ FUNC_01 & VEN_1106 & DEV_8446 & SUBSYS_10431487 & REV_1000 \ 4 & 27159E35 & 0 & 0001
Driver c: \ windows \ system32 \ drivers \ viahduaa.sys (6.0.1.10600, 2.10 MB (2,201,744 bytes), 09/05/2014 8:34 p.m.)
Thank you for your help,
Sacha
In the right thing.
OK status
Sacha
geposted Mon 12 May 14 @ 1:18 pm
DO you want to use the stereo to mono mode?
If set it to internal soundcard and make sure you set wasapiShareMode in config - options to yes if you are using any other applications that could use the soundcard parallel to VDJ.
geposted Mon 12 May 14 @ 1:32 pm
