Topic: loaded clipbank video to sampler
I loaded the clip bank videos to the sampler and the second i made them into a loop they stopped working.. Im in no rush.. just a heads up,
geposted Mon 12 May 14 @ 3:04 pm
I loaded a video into the sampler (a 5 minute mp4 of a laser show I run during Non video songs) and I was able to loop it without an issue.
(Mac Version)
geposted Mon 12 May 14 @ 3:56 pm
squincyPRO InfinityMember since 2007
(Mac Version)
Canu tell me how you did this step by step lol i'm on the Mac also !!
geposted Mon 12 May 14 @ 5:37 pm
I added the video by just dragging it from the file list pane in the browser Onto one of the empty buttons on the sampler pane on the right.
Then I went into sampler on the root list all the way on the left and turned on "loop" for the video.
Typing this from memory while not on the computer, but it should give you an idea.
geposted Mon 12 May 14 @ 5:57 pm
You can also access the sample editor like this:
HOLD CTRL on your keyboard and click the pad you want edit.
geposted Mon 12 May 14 @ 5:59 pm
