Topic: IDJ3 Won't control software
I connect my IDJ3 to my laptop (which, as far as i know, the controller is fully updated) and start the software but i can't control anything.
The sound is running through the soundcard fine and the mapper section picks up that it's plugged in, all the buttons are mappable etc. but i can't manipulate the software at all... any ideas?
geposted Mon 12 May 14 @ 3:30 pm
IGleedPRO InfinityMember since 2012
Just to let you know... you're not alone. My idj3 doesn't work properly either :(
geposted Mon 12 May 14 @ 3:53 pm
Could you please specify your Operating system ?
geposted Mon 12 May 14 @ 3:55 pm
Windows 7
geposted Mon 12 May 14 @ 3:57 pm
It does with version 7 ?
geposted Mon 12 May 14 @ 4:06 pm
works fine with version 7 :)
geposted Mon 12 May 14 @ 4:13 pm
got an update today build 1752.628
it has improved but intermittent. unplugging usb cable and plugging in again, sometimes regains control.
Is there another update soon?
geposted Tue 13 May 14 @ 7:45 pm
Still very intermittent! I have plugged the controller in two different Computers. My Gig laptop and my Home desktop computer.
Same Results - buttons and sliders not working on the controller
geposted Sun 18 May 14 @ 11:15 am
If there is a detection issue, then most likely it wont work with version 7 either. I don't see anything on the default definition/mapper of the unit to lead to a miss-detection. However, the unit (along with other Numark devices e.g Mixtrack ) are well known of detection issues on several OS.
So, first please try with the latest available build (1774) and also see if the unit is detected and working fine with version 7 too.
geposted Sun 18 May 14 @ 1:31 pm
1774.645 Unit is detected. Settings shows IDJ3 soundcard in Audio. Setting shows Keyboard and Numark IDJ3 (factory default) in Controllers.
The mixer always provides a signal (music) to amplifier and speakers.
The VDJ8 icon in the Windows taskbar has a pop up message saying "Numark IDJ3 - connected" when usb is removed and reinserted
VDJ 8 - buttons sliders and dials working Intermittent (can see a shadow slider sometimes. full colour slider jumps to a position when controller slider is moved, but then freezes
VDJ 7 - Working perfect, everytime
geposted Sun 18 May 14 @ 2:20 pm
Please do the following.. ..
Open VirtualDJ and goto OPTIONS tab, make sure the "Show Advanced Options" is checked and search for the createMidilog setting.
Set it to Yes, and close VirtualDJ.
Make sure the IDJ3 unit is connected and launch VirtualDJ.
Close again and post the content of Log Report.txt file here(open it with Notepad)
Notes:
Normally, if the unit is connected when VirtualDJ launches, the faders (volume, pitch, EQ etc) should report their initial positions and the sliders on the screen/skin should take the positions of the actual sliders. The "ghost" faders may be visible e.g. if you press SYNC on a deck, so the pitch sliders of the software and the hardware dont match at that time. For any other faders, this can only happen if you use a 2 deck controller with a 4 deck skin.
geposted Sun 18 May 14 @ 3:49 pm
Audio device found: name="2- iDJ3" vid="0x15E4" pid="0x0025" mid="0x0000"
Audio device found: name="IDT High Definition Audio CODEC" vid="0x111D" pid="0x76B2" mid="0x0000"
Audio device found: input name="Microphone / Line In (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x76B2" mid="0x0000"
Audio device found: input name="Microphone Array (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x76B2" mid="0x0000"
Audio device found: input name="Rec. Playback (IDT High Definition Audio CODEC)" vid="0x111D" pid="0x76B2" mid="0x0000"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_15e4&pid_0025&mi_00#6&227e8f87&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (in:0 out:1)
(trying to match sysex for \\?\usb#vid_15e4&pid_0025&mi_00#6&227e8f87&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global : found F07E062013F78019010307F7F7F7F04E31112913136029F7)
MIDI Device Identified by Sysex: \\?\usb#vid_15e4&pid_0025&mi_00#6&227e8f87&0&0000#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
geposted Sun 18 May 14 @ 4:12 pm
Ok, try with build that end at .647 or later
It will now provide a special button in the AUDIO tab of CONFIG, which will create a Master/Headphones audio setup (need to click APPLY after that)
We also corrected the identifiers.. old device ..not sure why we had a different value.. anyways, try to reproduce again with the latest builds (end at.647)
geposted Sun 18 May 14 @ 4:54 pm
Great! Looks like you have cracked it :)
Ive shutdown and restarted several times. All controls appear to be working fine
Thank you :)
geposted Sun 18 May 14 @ 5:20 pm
Pc Win 7 I 5
Found That I had 4 Files Running for VDJ8 removed 3 left idj3. I'm No PC geek So I'm Still Learning.
Now I Can Close And Open VDJ8 All Controls Work on IDJ3
This Was My Path Below. hope It Helps:)
Windows explorer/Documents/Virtual DJ/Mappers/Numark IDJ3 - Custom Mapping/XML Document.
sorry that didn't work either. back to VDJ7 i have issues with video in VDJ8 also
geposted Sun 18 May 14 @ 5:36 pm
philadisco wrote :
Pc Win 7 I 5
Idj3 was not showing up in the sound card setup. Unplug Idj3, open VDJ8 open Settings,audio, Then plug in Idj3 wait for it to show up in Card setting and apply then save
geposted Wed 28 May 14 @ 8:15 pm
