Topic: Karaoke Playlist
In VDJ 7 I used a karaoke playlist of songs I regularly sing. In VD8 these don't work. All my karaoke files are zipped MP3 & CDG files. I have the 'showZipkaraoke' set to yes & I can see all my files in the browser but if I select the playlist of karaoke files it appears empty. This also happens if I make a new one.
Can someone help with this please.
geposted Mon 12 May 14 @ 4:55 pm
Go to config, Browser, the find show Karaoke zip files,click yes and they show, up I had that issue also.
geposted Mon 12 May 14 @ 5:06 pm
The Songs List should show the content of the Playlist. If you need to see the Content in the Automix list, you will need to right-click on the Playlist and choose Load to automix.
If you dont see the files listed in the songs List then probably its the one the previous user mentioned .CONFIG->Options->Setting showzipKaraoke (set to yes)
geposted Mon 12 May 14 @ 5:13 pm
To cure this I had to add 'zip' in to the fileFormats in the browser options. My karaoke songs now show in my saved playlist!
geposted Mon 12 May 14 @ 5:53 pm
Ok, this shouldnt happen in the first place. It appears that there is a bug in the Playlists with zip file. Reported to Dev Team.
thank you for noticing.
geposted Mon 12 May 14 @ 6:17 pm
