Hello,
I heard about the silent updates feature in VDJ8 and wanted to know if the Mac version has this? I have left VDJ on for about an hour and reopened it and haven't got the 628 update. (Currently on 626..) Is it something wrong I'm doing or is there a link to this new update? Thank you.
geposted Mon 12 May 14 @ 4:59 pm
Some updates may be PC only and others Mac only - nothing to worry about.
geposted Mon 12 May 14 @ 5:00 pm
The part after the dot (.626) should not bother you... It will update only when needed. The part BEFORE the dot (1748) is the current build number... :)
geposted Mon 12 May 14 @ 5:01 pm
Thank you for the quick reply.
geposted Mon 12 May 14 @ 5:04 pm
