Topic: version 8 won't open for me mac osx 10.9.2
i figured i can keep the old version for back up.should i uninstall it or is something else wrong .need help thanks
geposted Mon 12 May 14 @ 5:03 pm
Delete the settings.xml from the VDJ folder and it should start then
Version 7 and version 8 can co-exist in your computer without any issues. So you don't really have to uninstall any of them.
ok thanks gonna try deleting xml right now
i only see database xml not a settings xml
thanks
never mind its open now .weird took an unusually long time
Have you installed version 8?
If so you should have a settings.xml
/Users/YOURNAME/Documents/VirtualDJ
i installed 8 ..no settings xml And its telling me i need to buy a license and won't take my code
found settings xml should i delete it still ? i closed and reopened it it came right open..
i thought i had to login with google ..i logged in with virtual dj info and I't showing my license
now
