Topic: Lost playlist elements
Hi DJs!
I was trying to load a playlist. Right click on it and load it in both the side list and the automix. Then I wanted to clear them, I selected all song by doing "CTRL+A" and "delete".
The result, it cleared all the songs for my playlist (m3u) and save it empty.
I lost a good playlist!
Anyone know what happened? Any ways for VDJ8 to not act like this?
Thanks!
geposted Mon 12 May 14 @ 6:40 pm
"Delete" will indeed remove the selected songs from the Playlist if this is loaded to Automix List, but it wont "empty" your Playlist,, unless you choose to "Save" from the Options. Really cant reproduce it here.
However, it will delete the entries and empty the Playlist (if all files are selected), if you do the above in the songs List. and thats normal imo. Same behavior exists for the Virtual folders as well.
geposted Mon 12 May 14 @ 7:03 pm
Well I didn't "save" so is there an autosave in the option that I need to turn off?
geposted Mon 12 May 14 @ 7:31 pm
Bump
geposted Wed 14 May 14 @ 11:00 am
DjeeThomas wrote :
Bump
What does 'Bump' mean?
geposted Thu 15 May 14 @ 3:12 am
Scrinson wrote :
DjeeThomas wrote :
Bump
BUMP to bring up somebody's post typically by posting the word "bump" on a message board
Can also stand for
Bring
Up
My
Post
geposted Thu 15 May 14 @ 8:27 am
gbeulPRO InfinityMember since 2007
re:Bump
there is a parameter in settings wich will automatical save the lists
<savePlaylist>unplayed</savePlaylist> i guess default is "smart"
<showM3UAsFolders>yes</showM3UAsFolders>
i gues the combination of this two will case your Problem
geposted Thu 15 May 14 @ 8:33 am
prasanfPRO InfinityMember since 2011
Thanks for pointing this out. I just went and disabled the "saveplaylist" option. That is a terrible option! Should never autosave playlists!
geposted Sun 18 May 14 @ 9:09 pm
