Hi using the software with my denon 6000mk2 , but on My macbook pro using Mavricks and on my windows 8,1 machine , i get a message saying the this mapping wont work for vdj8, its fine on vdj7 , can you help at all with this please ? couple of other things , how do you on vdj8 get the video screen to appear on the second tv screen im confused by this, also , If I want to copy a playlist from Traktor and all the que points how do I copy into vdj8
Thanx Mark
Thanx Mark
geposted Mon 12 May 14 @ 9:40 pm
Can you please post here a screenshot that shows the message you re getting for the incompatible mapping ? or whatever message you are getting ?
geposted Mon 12 May 14 @ 9:51 pm
