Topic: mac book pro problem
to all vdj dj's any one having problem with mac pro will not open?
geposted Tue 13 May 14 @ 1:36 am
What is your Operating system ?
Do you see a settings.xml file in Documents/VirtualDJ folder ?
EDIt. In case you dont have one, and since it wont generate if the software crashes, please read the email i ve sent you and use the attached file.
geposted Tue 13 May 14 @ 3:40 am
i've got the same problem,
vdj doesn't open and show this messag : error FileNotFound
Macbook pro 2,8 Intel Core I7 8Go DDR3, Mac Os 10.9.2, SSHD 1To / 32Go
thanks for help me
geposted Thu 15 May 14 @ 8:06 am
Sorry to bring up an old thread.
Has anyone found how to resolve the FileNotFound error?
I recently formatted my macbook and reinstalled VDJ8 and get this error when trying to open it. Need to use it tonight and don't have time to do a format before the gig :/
geposted Sat 07 Feb 15 @ 7:03 am
Did you try to remove VirtualDJ from applications, then use the installer to re-install it?
geposted Sat 07 Feb 15 @ 8:32 am
Yes but i've got the same problem.
geposted Sun 08 Feb 15 @ 2:11 am
