One of my favourite effects [ramp_delay] does not work with virtualdj8..All it does is stop the song.
geposted Tue 13 May 14 @ 7:24 am
Just confirmed this. Activating it results in silence.
It is a very old effect though (VDJ 5)....
geposted Tue 13 May 14 @ 7:29 am
what can I do...is there any other effects that can do the same?
geposted Wed 14 May 14 @ 7:43 pm
dont think i played around with that effect, but i would guess it basically sets a ramp up time to make VirtualDJ play button act like a slow belt driven turntable start up?
you can change these settings in options, just search for ramp in the options, and you can change both ramp start and ramp stop time
(and you can map these to your controller too should you want.. )
that being said, i'm sure most all v7 plugins will be remade to work for v8 in no time ;)
geposted Wed 14 May 14 @ 7:54 pm
No, it's an audio delay effect - like a repeating echo. You can set the amount of repeats (which gradually fade away) and you can also filter it and change the key.
romiestar, there are plenty of VSTs you could try. Some free ones here
geposted Wed 14 May 14 @ 8:03 pm
ah ;) makes sense.. delay ..
yeah if the fx isnt working with v8 , hopefully the guy making it will have a v8 version for it real soon
geposted Wed 14 May 14 @ 8:06 pm
Is Deun-Deun still around?
http://www.virtualdj.com/addons/14161/Ramp_Delay.html
geposted Wed 14 May 14 @ 8:09 pm
he is ;) hopefully he will update them soon
geposted Wed 14 May 14 @ 8:11 pm
