Hello
since the build 1751 I have a pop up that appears and downloading message on the skin which stays there continuously.
![](/image/29217/135023/pop up.png)
Bonjour
depuis la build 1751 j'ai un pop up qui apparait et le message downloading sur la skin qui reste là en continu.
Bonjour
geposted Tue 13 May 14 @ 7:31 am
Yes, something happened during uploading that build.
New build is up (1752). Please let the software update.
In case you cant get the software to be updated, please re-install the software (using the installer) and let it update to the latest build.
geposted Tue 13 May 14 @ 7:33 am
Hello DjDad
If build 1752 is already online Vdj does not auto update because I still hang in 1751.
Is there another way to do this update?
Si la build 1752 est déjà en ligne Vdj ne fait pas la mise à jour automatique car je reste bloquer à la 1751.
Y a t'il un autre moyen de faire cette mise à jour ?
geposted Tue 13 May 14 @ 7:42 am
As above, you will need to re-install the software
geposted Tue 13 May 14 @ 7:43 am
Ok thank you.
geposted Tue 13 May 14 @ 7:44 am
solved thank you.
geposted Tue 13 May 14 @ 7:50 am
appears to be fixed, they haven't mentioned or edited the change log text though during fixing this..
geposted Tue 13 May 14 @ 7:52 am
