install on mac mavericks os x, ddj- ergo the microphone does not work. identical settings as vdj 7.4.1 output headphone/speaker- sound card ddj-ergo/ input microphone still no microphone. please help!!!!
geposted Tue 13 May 14 @ 7:40 am
is this a bug, that vdj is still working on?
geposted Tue 13 May 14 @ 9:12 am
Yes I get the same issue. I'm trying to use the AUX and no matter what I do in settings, there is no line level at all. I switch to v 7.4 and all is well. I also need help on this.
geposted Sun 29 Jun 14 @ 11:36 am
there is a button on the skin to activate mic maybe your not hitting it?
its on the master tab in the center might have to use that to activate aux as well not sure.
the mic on my ergo definitely works but i am using windows not mac
![](/image/69721/140457/Capture.png)
geposted Sun 29 Jun 14 @ 12:11 pm
I can confirm that I'm having similar issue.
VDJ v.8 - Build 1845.699
Microphone does not work with a mac
geposted Sun 29 Jun 14 @ 9:29 pm
im running windows 8.1 using a Hercules dj console 4mk mic doesn't respond well like it did in 7.4 ive tried to remap the mic but no fix can u guys look into this its shows up in the mapping under key is mic under action is djc_mic.
geposted Mon 30 Jun 14 @ 8:39 pm
in addition I can use mic with keyboard but it wont activate with my controller mic led button in 8 like in 7.4
geposted Mon 30 Jun 14 @ 8:41 pm
