Topic: [FIXED] Can not delete tracks in Automix on Mac using delete key
Reported yesterday but there have been a ton of updates since then... this problem still exists.
Add tracks to Autoplay. Usually I can select all and hit delete and that removes the tracks. This does not work. (Works on the Windows side but not on Mac)
Thanks!
geposted Tue 13 May 14 @ 8:30 am
Fixed in version 1752
changelog wrote :
-Option+Delete on mac to delete files from automix
Ah, so you need to hit option and delete?
That is different from the old version. Why not just delete after selecting all?
Unsure - there is probably a reason somewhere.
Atleast there is a solution!!
Absolutely... thanks again!
