Okay, just downloaded & installed VDJ 8 on my data drive (D:) for testing ...... VDJ 7 is installed on my OS drive (SSD C;).
Both programs have their own folder and directory structure for plugins, skins etc .....
VDJ 8 is working ok, Installed Scott's Milkdrop plugin (which is amazing) and works ok in 8
Went to run VDJ 7, which has been flawless, to test the milkdrop plugin (this is my main PC NOT my gig PC) and get this error .......
.jpg)
Any Ideas ......... both sets of folders are still there !
Don't really want to do a fresh install of VDJ7 if there is a simple solution.
TIA
.jpg)
TIA
geposted Tue 13 May 14 @ 8:39 am
Have you manually deleted the Skin files for V7?
If so you will need to put the default 2 deck skin for V7 back as a minimum for it to load.
geposted Tue 13 May 14 @ 8:50 am
Just checked both folders VDJ 7 - 2 Deck Skin Zip, 4 Deck Skin Zip, 6 Deck Skin Zip and in the VDJ 8 skins folder, the default VDJ 8 skins zip.
geposted Tue 13 May 14 @ 8:56 am
Both folders?
Yes ...... As per my 1st post ...... VDJ 7 On C: VDJ 8 On D: Install of 8 created a separate folder structure on the D drive for 8
geposted Tue 13 May 14 @ 9:01 am
I would suggest a "repair" install of VDJ 7 then.
geposted Tue 13 May 14 @ 9:02 am
I was afraid you'd say that ....... Damn you V8 :-)
Many thanks Dan
Many thanks Dan
geposted Tue 13 May 14 @ 9:03 am
Sorted :-) Now running Milkdrop, Sonique in VDJ 7, will try 8 next !
geposted Tue 13 May 14 @ 9:32 am
Oh Dear ....... VDJ 7 up and running ok, now to try 8 ........
.png)
So much for them co-existing on the same PC ............. :-(
Here's a close up of the error !
.jpg)
And yes ...... the default VDJ8 Skin zipfile is there.
.png)
.jpg)
geposted Tue 13 May 14 @ 9:51 am
Not showing up as new post :-(
geposted Tue 13 May 14 @ 11:38 am
You must have done something to the Skin folder in the VDJ folder of My Documents.
the only time i have seen this is when they haven been deleted or moved.
geposted Tue 13 May 14 @ 11:44 am
Haven't changed\moved\deleted a thing .......
Deleted VDJ 7 now and just leaving 8 on my main PC for further testing :-(
geposted Tue 13 May 14 @ 12:46 pm
I reckon it's related to one being on C: and one on D:
I've been using 8 and 7 alongside each other on two different PCs (installed to C:) and both are fine.
I do have a laptop with two drives that I could experiment with......
geposted Tue 13 May 14 @ 12:50 pm
But that *shouldn't* make any difference if both versions CAN co-exist on the same PC, or should it :-(
My C: Drive is a 60GB SSD ....... D: is 1TB (partitioned into 4)
geposted Tue 13 May 14 @ 12:57 pm
