Topic: Resize the window with a mouse??
This might sound like a dumb question, but when i un-maximize, where is the grabzone to move the v8 window and how can i make v8 window smaller???
un-maximizing and hovering over the bottom right corner wont let me shrink the window and i cant find the grabzone...?
geposted Tue 13 May 14 @ 9:47 am
Which skin?
These needed to be coded into the skin.
The default skin has a grabzone on all four sides and the resize option is always bottom right.
Just checked again and nope. im running 1280x1024 resolution.
will check again on larger monitor (1920x1080)
