![](/image/38038/135063/lekkerland.2.jpg)
i have mentioned it before now it happend.
the message says you can not install vdj twice (OK) but here in the company with this proxy no download of updates in backround are possible (limited internet access)
if downloaded the MSI and thought that an manuall install like with V7 is possible.
but it tells me to deinstall VDJ8 what will deinstallation do with my V7 installation what happend to my Settings and mappers for VDJ 8.
please advice Manually Update with MSI should be Possible
best regrads
geposted Tue 13 May 14 @ 10:03 am
When uninstalling you will be presented with an option (pop up) to delete your settings and files.
Make sure you press NO and then only the software will be deleted.
geposted Tue 13 May 14 @ 10:13 am
ok thanks
geposted Tue 13 May 14 @ 12:17 pm
