BUILD 1752
BUILD 1759:
BUILD 1761:
BUILD 1765:
BUILD 1772:
BUILD 1774:
BUILD 1781:
BUILD 1782
BUILD 1785
- Fix zipped karaoke files not showing up in playlists
- 'backspin' action added
- [Mac] Fix cursor in POI Editor
- Fix search_log action
- On first install, tracklistings from v7 are copied to history folder
- cdg files renamed/copied when copying or renaming file from within vdj
- [Mac] Fix sysexid controller detection when no vid/pid
- [Mac] Option+Delete on mac to delete files from automix
- Potential VST Crash fix
- [Mac] Use 'Plugins64' folder on 64bit version instead of 'Plugins'
- Fixed issue with Per-Controller licenses
- Show plugin incompatible popup only when selected from drop down
BUILD 1759:
- Fix filter folder endless loop crash
- Option to hide liveFeedback
- Logout ask for confirmation if no internet connection present
- line_in action query works correctly with input number as parameter
- deck select active can cycle through 4 decks like v7
- Fix custom buttons with multiple actions selection
- Disable line_in reloads previous song
- Backspin effect added - n.b. for those with V7 effects still installed the new one is Backspin rather than backspin :-)
- Beatgrid default grids added
- Fixed Controller-License still showing popup message with valid license
- Softer limiter for deck output
- sampler_pad repeat fixed when used as keyboard
- Reduce chance on audio drops when switching sample bank
- Fix possible crash
BUILD 1761:
- Use newer D3DX libraries when available
- Ensure video window fits on screen in windowed mode
- Fix drag&drop indicator when coverDrag is disabled
- BrakeStart effect added
- New action shift_all_cues
- Video crossfader auto and link mutually exclusive
BUILD 1765:
- Fix podcasting
- Fix possible crash when reading corrupted wav tag
- Fix potential crash in touch screen's context menu
- Force context menu to stay on the same monitor
- Modified EULA (allow broader use for multi-users or multi-computers)
BUILD 1772:
- Fixed some native controllers definition didn't load properly
- Changed priority of custom controller definitions ("force-xx.xml" > native > "xx.xml")
- Fixed graphic for left timecode meter on default skins
- Fixed cover artwork on Pioneer CDJ
- Show memory errors on system tray instead of popup
- Fixed various crashes
BUILD 1774:
- autoupdate don't wait for next launch if nothing is playing
- hide v7 plugins that are known to have compatibility issues
- fix bug when modifying a factory mapper while a file "custom mapper" already existed
- fix controller list in license panel
- fix potential crashes
BUILD 1781:
- fixed various crashes
- fixed scs.1d motorized controllers
- new config option keyDetection to choose between broad and electronic
- exclusiveAudioAccess (ex 'wasapiSharedMode') now off by default
- fixed timecode sometimes stopping when reaching the end of the disc
- improved ansi support for reading playlists
BUILD 1782
- fixed potential freeze when streaming CU content with b1781
BUILD 1785
- fixed "stop" keeps the previous working cue in the list of cues to cycle through
- fixed browser sort
- switch pfl on timecode scratch
- cdj9000/400 show correct icons on lcd display
- controllers with sampler pad on both sides sync on master deck, not on their deck (unless samplerOutputToTriggerDeck is on)
geposted Tue 13 May 14 @ 10:27 am
