20.07.2015
Build 2362
-Update chinese translation
-faster sorting on usb/network drives
-force content shown in search content unlimited folders even with filters active
-New option autoSideview to have sampler_bank option switch sideview to sampler or not
-Fix sample syncing with variable bpm tracks
-fix bug in keyengine
-Copy database info when copying a folder
Build 2362
geposted Mon 20 Jul 15 @ 9:17 am
26.07.2015
Build 2369
-Fix video fading during Glass and Grid transitions
-Fix flicker at start of Shatter and Droplets transitions
-fix search for upper-case russian characters
-fix some possible automix lock issues
-with splitHeadphones enabled, headphone volume controls both sides
-Fix possible crash when a download is canceled
-browser_sort '+bpm' can be correctly queried (for leds)
-Fix effect list not showing up for LE mode
-Skin drop zones follow draw order
-Split headphones headphone channel is mono mix of headphone instead of only left channel
-Fix some video samples not returning to start correctly
-Fix lottery effect image list not resetting when selecting a new folder
Build 2369
geposted Sun 26 Jul 15 @ 11:16 pm
03.08.2015
Build 2378
-Compatibility with windows 10
-browser_sort '+bpm' fix
-2-deck skin fix for rhythm wave left/right deck logic
-Make effect GUI buttons more obvious when active
-New video effect 'Shake'
-New VDJScript command undo_load to unload the current track and reload the previous track
-Fix possible crash after lost sound card is available again
-autocue mode cue/skip silence added to skip silence when no cue is available
-Fix rhythm wave not updated on left side when starting to load from middle of song
-Fix green line when using dxva on some videos
-Fix on screen keyboard not working correctly on windows 10
-fix custom browser lists not updating correctly when switching from list to grid view
-source="karaoke" added for filelist skin object
-param_equal accepts 2 strings to compare query action with a string (example: param_equal "`get_browsed_song 'type'`" "audio")
Build 2378
geposted Sun 02 Aug 15 @ 11:24 pm
09.08.2015
Build 2389
-Fix slideshow sometimes getting stuck on black image when removing an image
-edit_singer fixed for custom browsers
-loop_roll can now be used on videos as well (switch on in plugin settings, or using 'loop_roll video' action)
-fixed loop action not always working correctly when loop size defined in milliseconds
-Add video option to slicer (switch on in plugin settings, or using 'slicer video' action)
-saveUnplayedToSidelist option will no longer add a track to the sidelist if it is already there
-items in the sidelist can now be added to the automix list directly by using their context menu
-fix potential crash in liveFeedback
-prevent history file to grow too much when no internet connection
-Performance improvement for track scan
-Fix wasapi audio glitch at startup in some cases
-Fix elastique glitch on first pitch change
-Fix some potential noises when using pitch quality 2
Build 2389
geposted Mon 10 Aug 15 @ 4:26 am
10.08.2015
Build 2391
-Fix regression crash in b2389 with ScanBeat when seeking
Build 2391
geposted Mon 10 Aug 15 @ 12:08 pm
12.08.2015
Build 2398
-Master VU meter reflects master_balance
-Fake Master no longer affects master volume
-Fix video slideshow not progressing to next videos when duration is set to full
-when controller is defined with 1x1 sample pads, the selected sample (sampler_select) is highlighted on the skin
-cda audio track always reloaded to ensure correct file when inserting a new cd
-new VDJScript command 'browsed_file_rename' to rename the currently selected file in the browser
-new VDJScript command 'browsed_file_analyze' to (re)analyze the currently selected file(s) in the browser
-new VDJScript command 'reanalyze' to reanalyze a file loaded on a deck
-'No 3/4' option added to Loop Roll to skip the 3/4 loop roll when using the slider parameter
-new setting quantizeLoop (VDJScript quantize_loop) adjusts loop positions to snap to a quantized grid position
-new setting quantizeSetCue (VDJScript quantize_setcue) adjusts the setting of cue points to snap to a quantized grid position
-setting smartCueQuantize renamed to globalQuantize
-Fix incorrect aspect ratio on some wmv's
-Fix potential crash in sound config window
Build 2398
geposted Thu 13 Aug 15 @ 5:25 am
16.08.2015
Build 2412
-15% performance improvement on launch speed
-fix potential problem when upgrading to windows 10
-Fix b2389 regression bug causing sound and waveform to get out of sync in some cases
-fix for temporary cue preview when quantizeSetCue enabled
-fix login window hidden behind config window on Mac
-fix seeking in track edits for preview
-Fix position shown in track cleaner
Build 2412
geposted Mon 17 Aug 15 @ 4:20 am
24.08.2015
Build 2425
-Fix regression causing reduced sound quality when mastertempo is disabled and pitchQuality is 2
-Fix cue_stop crash (#2399 regression)
-Improve scratch sound quality
-Add videoCreateLinkOnDrop option
-Fixed bug with removing items from file list when some items are still selected
-Fix filter folder 'User 1 is text'
-Improve use of colors in filter folders ('color=red' and 'color=255,0,0' both work)
-Remember last path used for Copy To or Move To
Build 2425
geposted Mon 24 Aug 15 @ 5:27 am
31.08.2015
Build 2436
-Fix delay between sound and waveform after seeking in mastertempo quality 2 (#2425 regression)
-Fix green on some videos with dxva
-Fix possible analyzer crash
-Fix unable to rename virtual folder with no files in it
-Fix custom context menu crash
-Fix detailed waveform colors slightly off and possible crash
-Fix possible crash in sync action
-Fix possible crash in Camera plugin
-Fix video getting stuck in some cases when using loop roll with video enabled
-Fix autogain not applied sometimes when using load & play in a single action
-Fix action auto-complete preferring synonyms
-Track Cleaner now correctly shows and prelistens modifications
-Some performance optimizations
Build 2436
geposted Mon 31 Aug 15 @ 5:49 am
03.09.2015
Build 2438
-Fix possible crash in skins using racks
-Fix crash when generating a video edit by drag&drop
-Fix possible audio encoder crash
-Fix green videos when dxva is enabled on nVidia
Build 2438
geposted Sun 06 Sep 15 @ 5:38 pm
06.09.2015
Build 2441
-Auto_crossfade and video_transition can move to a specific location
-Prelisten start position stored in config
-Fix crash on endless recursion in browser
-Fix deleting custom mapper
-Fix loop_exit jumping to bad slipmode position when no loop was set and looproll mode was on
-Fix mac crash when loading or analyzing a file with corrupt length tag
-Fix mac showing certain notifications twice
-Fix Cube and Satellite transition position off
Build 2441
geposted Sun 06 Sep 15 @ 7:02 pm
13.09.2015
Build 2453
-sampler_group_mute action added
-ONEXIT support for keyboard mapper
-Fix images in samplebank not showing on video output if samplebank was loaded before video engine initialized
-Fix loop_exit jumping to slip mode position when no loop is active
-Fix possible track edit crash
-Fix possible lock up of loading songs after downloading content unlimited song to cache on mac
-Fix video memory leak
-Fix playback of some bad mpg files
Build 2453
geposted Sun 13 Sep 15 @ 6:07 pm
14.09.2015
Build 2454
-Fix recording/broadcasting crash (2453 regression)
Build 2454
geposted Mon 14 Sep 15 @ 6:46 pm
20.09.2015
Build 2465
-Fix getRemixFromFilename
-Fix crash seeking some cdg files
-Fix memory leak when reloading skin
-Faster response of automix_skip
-Fix paths on database stored incorrectly for files on other drives when the drives are not writeable
-Fix database not set to not writable when permissions don't allow it
-Fix browser file list for vdjRemote in sidelist view
Build 2465
geposted Sun 20 Sep 15 @ 11:53 am
04.10.2015
Buid 2479
-Reverb and Echo have switch to enable trailing stop when disabling the effect
-Feedback and Highpass parameter added to flanger
-Read Serato track colour from tag when cues are read
-Clone also clones loop
-Fix automix_skip when deck is paused while automix active
-Fix cue_name action problem in some cases
-Fix possible plugin issue when showing effect gui
-Fix possible track cleaner crash
-Fix possible video crash
-Fix detection of ASIO drivers with REG_EXPAND_SZ type (like Rane ASIO driver)
-Fix some problems with bad vga drivers
-Fix cdg using scroll preset
-Fix advanced audio channel selection hidden behind config window on Mac
-Fix renaming playlists and only changing the case
-Fix video flickering in track edit when source length was 0
-Fix possible batch analysis lock up
Buid 2479
geposted Mon 05 Oct 15 @ 4:17 am
05.10.2015
Build 2483
-Fix regression crash when undocking effects
-Fix scratch/size cursors not working anymore after drag (regression)
-Reverb trail continues a bit longer
-Fix ape file playback
-Fix retina regression on mac
-Fix main window on mac getting behind dock when maximized and restoring video window from maximized
Build 2483
geposted Mon 05 Oct 15 @ 9:31 am
11.10.2015
Build 2497
-Localization of default skin (texts and tooltips)
-Longer echo trail
-Fix dont import white track colour from Serato tags
-Fix potential crash when trying to read password-protected zip
-Fix freeze that could happen with some bad ASIO drivers during init
-Fix rare crash favorite folder that no longer exist
-Fix rare crash in tag editor
-Fix rare crash when analyzing file
-Fix Update prompt no longer hidden behind video window on Mac
-Fix audioOnlyVisualisation drop down not enumerating when language was not English
-Fix occasional vob/mpg problems on mac
-Fix secondary skin windows opening on start on mac, even when shown=false
-Fix sampler_group_mute
Build 2497
-Longer echo trail
geposted Sun 11 Oct 15 @ 5:40 pm
12.10.2015
Build 2500
-Fix regression preventing Tag Editor to open
-Fix sampler_group_* actions when used by index instead of name
-Fix rare crash after closing undocked effect window
Build 2500
geposted Mon 12 Oct 15 @ 8:46 am
20.10.2015
Build 2520
-Fix rare mac crash when scanning audio devices
-Fix rare tag editor crash
-Fix wma lossless playback
-Fix rare lockup on some vst effects
-added option 'Ignore' to move internal plugins to ignore list
-Add custom mapping option to mapper list when no mapper is present to make it more clear how to create a new mapper
-v7 filter effect added to blocked plugin list since causes crash on release
-Options expanded by default when advanced options disabled
-Fix Title video effect showing previous song when started
-Add frequency selection to Shake video effect
-Fix ASIO issue when using inputs and ASIO samplerate different from internal samplerate
-Update for Chinese translation to include skin translation
-Implemented saved loops with fixed numerical slots
-New VDJScript command saved_loop which saves or loads and jumps to a saved loop
-New VDJScript command saved_loop_prepare which saves or loads a saved loop
-Fix possible crash in set_browsed_file_bpm
-Fix systray notifications in windows 10
-Xiami used for netsearch audio when profile country set to chinese, or language set to chinese
-Fix undocked plugin windows on mac
-fix pen input
-invert_deck action added to swap left deck between deck 1 and 3, or right deck between deck 2 and 4
-left and right added as deck assign option for single deck controllers
-When Chinese is selected as language, Microsoft YaHei is selected as font to get consistent character size
-Existing saved loops with no slot and no name assigned slot number automatically so they can still be accessed
-Add 'Content Unlimited' text above content unlimited search results
Build 2520
-fix pen input
geposted Tue 20 Oct 15 @ 2:49 pm
20.10.2015
Build 2522 (Public)
-fix pen input
Build 2522 (Public)
-fix pen input
geposted Fri 06 Nov 15 @ 5:43 am
