I used the Reloop Mix 4 today and the filter knob frequencies are way to harsh. If the knob is turned completely to the left it cuts ALL the frequencies. I prefer the way in 7 where there was greater control/range of the frequencies. Now it seems to be pretty pointless using the filter control as it seems to be either on or off with not much variation in frequency.
geposted Tue 13 May 14 @ 10:57 am
I thought that too actually. Might be a way to change the sensitivity in the mapper?
geposted Tue 13 May 14 @ 1:01 pm
Agreed. Ability to change things like Q and resonance would be nice.
I'm used to Allen & Heath filters!
geposted Tue 13 May 14 @ 1:18 pm
I'm glad its not just me. The filter is pretty much no use with no gradual frequency change. :(
geposted Tue 13 May 14 @ 5:10 pm
Not tried this but there is a setting in advanced config for:
filterDefaultResonance
geposted Tue 13 May 14 @ 5:11 pm
You cab change the resonance of the filter in the settings
Three fixed choices. Not much difference between them.
Oh well, I have filters on my mixer.
geposted Tue 13 May 14 @ 5:20 pm
I finally got a chance to try the 4 options and they all seem the same.
This is something I use a lot for mixing and effects. Hopefully it will be fixed or restored to how it worked in 7.
geposted Sat 17 May 14 @ 1:27 am
I haven't tried it yet, but if you want less range, I assume there is still a param_multiply option that you can apply to the skin or to the mapper for your controller. I know that doesn't change the problem but it would be a work around for you at least.
In v7, I used something like this: param_multiply 90% & param_add 5% & filter
or change to multiply by 80% and and 10% :-)
geposted Sat 17 May 14 @ 5:40 am
filter_resonance action is also available btw if u want to assign a custom (knob) as well
geposted Sun 18 May 14 @ 9:09 pm
