Topic: OPTIONS PROBLEMS
the options (config) windows like to close on its own before I have had chance to make changes,for no reason...im using windows 7 64bit.
geposted Tue 13 May 14 @ 10:59 am
This has been noted and is being investigated!!
geposted Tue 13 May 14 @ 11:01 am
Noticed this only happends when i start up w/o my maya44 usb connected
(in other words, when my sound config is wrong)
geposted Tue 13 May 14 @ 11:53 am
jucenicPRO InfinityMember since 2012
I have the same problem, What was the solution?
geposted Sat 17 May 14 @ 12:55 pm
