opening the tag editor and hitting get artist title from file name and saving the tag corrects it, same files in same directory
other system info:
OS windows 8 64bit
dual install with 7 and 8
version 8 build 1752.632
version 8 has had 'one restore to defaults' applied
images as requested below
I wont re tag files , as I will be using 7 live until 8 has settled
VDJ7
![](/image/10503/135336/vdj 7 file info.jpg)
VDJ8
![](/image/63104/135337/vdj file info.jpg)
hope this helps
other system info:
OS windows 8 64bit
VDJ7
VDJ8
hope this helps
geposted Wed 14 May 14 @ 7:57 pm
whoops
may help if I show exactly the same file
![](/image/77666/135338/vdj8 file info.jpg)
geposted Wed 14 May 14 @ 8:03 pm
When playing karaoke when you load deck 1 and deck 2 with a karaoke file you can see both on screen usually one is circuling around the screen whats up
geposted Wed 21 May 14 @ 6:55 am
