I host trivia games using the slide show function in VDJ 7. I would leave the slide show option off, and pick the slide I needed to show on the screen. Once I had all the answers in, I would pic the next slide. This doesn't seem to be possible in VDJ 8 anymore. It only allows you to pic a folder and control time of transition. Is there another way to accomplish this?
geposted Tue 13 May 14 @ 3:00 pm
How do you create a folder in VDJ 8 for images I have on my desktop?
geposted Wed 14 May 14 @ 2:25 am
As far as I know you use any folder you want for images. You just can't select individual images any longer. You just pick the folder you want from the slide show settings panel.
geposted Wed 14 May 14 @ 6:15 am
