Ddj-sx is not being properly recognized. I have it set-up as:
Audio: speaker + headphones
Sound card: Pioneer ddj-sx
Controller: ddj-sx
Mapping: ddj-sx
Deck: auto
It partially works, what I can't get to work is the mixer sliders on the controller.
I rebooted my computer and controller, and tried everything I can think off. Still not working
Running on windows 7
dell xps
I just went back to VDJ7 and my controller works perfect, so it must have something to do with VDJ8
Any suggestions would be greatly appreciated.
Controller: ddj-sx
Mapping: ddj-sx
Deck: auto
dell xps
geposted Tue 13 May 14 @ 8:05 pm
Do you have any custom definition in the Devices folder ? If so , please remove it and re-launch.
Make sure you are using the default - factory mapping for your tests.
geposted Tue 13 May 14 @ 8:08 pm
The only folders that I have in Devises are: controllers.dat and pioneer DDJ-SX mapping.
geposted Tue 13 May 14 @ 8:46 pm
I've also noticed that when I reboot my computer VDJ resets controller to Keyboard...?
geposted Tue 13 May 14 @ 8:56 pm
In the /VirtualDJ/Devices folder, normally no file should exist (except from the controllers.dat). So if you have any files related to the DDJ-SX , please remove them (or move them to a safe place if you still need to use that for version 7)
In CONFIG->controllers tab, you should be able to see the Pioneer DDJ-SX (along with the keyboard etc) and from the right side (Mapping), please select the factory default one.
VirtualDJ does not reset any mapping. But by default the Keyboard is selected from the left-side (available devices). Each time a device from the left side is selected, you will see on the right-side (mapping) the selected mapping file (factory default or other name for custom ones)
If a device is selected from the left side, this doesnt mean of course that the other devices are not functional.
geposted Tue 13 May 14 @ 9:12 pm
i am having the same issue.. I'm using a macbook pro & when i have my ddj sx running on 8 everything seems to work except for the volume sliders on deck one & the strip search on deck 2. any ideas would be great ..
geposted Sat 17 May 14 @ 12:25 pm
i have a similar issue (DDJ-T1)
i started a toppic here:
http://www.virtualdj.com/forums/187304/VirtualDJ_8_Pre-Release_Forum/Custom_mapping_is_not_working__%28no_deck_select%29__Pioneer_DDJ-T1.html?search=djcannonball&page=1
it seems that the new VDJ-script is not fully completed yet, not fully compatible with all kinds controlers (yet)
geposted Sun 18 May 14 @ 5:42 am
I have a DDJ-SX, and running Windows 8.1. Absolutely no problem with the controller here.
geposted Sun 18 May 14 @ 9:51 am
