VDJ7 shows all cover art from ID3tags
VDJ8 shows the majority but has large batches missing
Is there an option in settings I have wrong? or is it a pre-release snag
geposted Wed 14 May 14 @ 4:27 am
Are the covers actually in the iD3 tags or did you add the covers yourself in V7?
geposted Wed 14 May 14 @ 8:44 am
I added them in itunes
geposted Wed 14 May 14 @ 10:18 am
Right click on folder containing the files, then Batch-> Load Tags
geposted Wed 14 May 14 @ 10:21 am
Batch-loadtags didnt work :(
Tag editor in VDJ8 just shows a coloured square. When I click on the square, the cover art selection screen opens and says "Tags - None" with a black square
geposted Wed 14 May 14 @ 11:04 am
Do you see the covers when opening the songs within Winamp, VLC Player or any other Software ?
As i remember iTunes does not save them into files - it stores them in a internal Database.
Greets, Heiko
Greets, Heiko
geposted Fri 16 May 14 @ 1:18 pm
Haven't had a problem with any tags in V8 - use MP3Tag to do all of mine.
geposted Sat 17 May 14 @ 8:58 am
if the tag box is blank but u see other cover art like iTunes amazon etc right click on the pic u will see save to tag this will fill in the blank box then close the cover window and don't forget to save in tag editor
geposted Sat 17 May 14 @ 10:34 am
I also use MP3 Tag editor as well as itunes :) Cover art is present in all other software including VDJ7.4
In VDJ8 the cover art tags that are missing, show only one black box as if the cover art is not in the tag
geposted Sun 18 May 14 @ 3:56 am
Question: Covers that are applied to an MP4 via version 8.0 are these visible within 7.4?
where does 8.0 store the image files.
in 7.4 it was a jpg file with the same name as your file.
geposted Sun 18 May 14 @ 5:57 am
