Topic: HideSong Info on Custom Buttons ?
RobRoyPRO InfinitySenior staffMember since 2012
HideSongInfo can be set in options to yes or no.
in some former builds it was possible to do this also with a custom button
as far as i can see this is not avaliable anymore via button editor...right...?
geposted Wed 14 May 14 @ 5:15 am
As all settings, this can be controlled using the setting action (setting 'settingname' 'value')
so just use setting 'HideSongInfo' (will toggle between yes/no)
geposted Wed 14 May 14 @ 5:18 am
thx for reply...so no option anymore to do this via custom button ?
EDIT: DONE..!
geposted Wed 14 May 14 @ 5:22 am
what do you mean ? custom buttons can take vdj script actions,and the above is one of them.
We never had a specific action for that feature, and using the setting action, you can control any setting you need.
geposted Wed 14 May 14 @ 5:23 am
I just tried assigning HideSongInfo to a custom skin button and it does nothing.
Ah, you have to type "setting" first, so setting HideSongInfo
geposted Wed 14 May 14 @ 5:28 am
thats it...;-)
geposted Wed 14 May 14 @ 5:58 am
