VDJ 8 is not getting some knobs midi info from my Xone 4D.
I had the exact same problem in the past with VDJ 7 when it went from 7.05b to 7.1 and it was solved by cstoll from the Support Staff with a customized map.
I tried to use this map and the default one but the problem, with VDJ 8, still remains.
It is, for sure, a VDJ 8 problem because it works perfect with VDJ 7.4.1.
These are the knobs not working.
![](/image/95002/135229/Xone4D_User_Guide_Highlights1.jpg)
geposted Wed 14 May 14 @ 5:34 am
Maybe I should try with my Xone 1D too...
geposted Wed 14 May 14 @ 5:38 am
Do you have that customized mapper/definition that our Team made for you ? Could you please send those to babis@virtualdj.com and if possible specify the names that those keys have in the mapper as we dont currently have the unit and the silkscreen will not help us much.
Thank you
Thank you
geposted Wed 14 May 14 @ 5:41 am
djdad, I will send it ASAP.
geposted Wed 14 May 14 @ 6:07 am
Info requested already sent.
Thanks for the quick answer.
geposted Wed 14 May 14 @ 8:00 am
Still waiting for a solution...
geposted Thu 10 Jul 14 @ 1:25 pm
The additional keys should be available in builds ending at .718 or later. To get the latest controllers version (the 3 last digits of the build number), launch version 8, wait for a few minutes (to get silently updated ) and relaunch.
geposted Thu 10 Jul 14 @ 7:19 pm
