Topic: SBDJ Graphic Equaliser
Hi
I have downloaded and installed SBDJ Graphic Equaliser plugin which has been made for Virtual DJ 8. Can someone tell me how to get it started i have been through the program but I cannot seem to find it.
Thank you
geposted Wed 14 May 14 @ 6:52 am
Didnt try it yet myself, but would assume its in the effect slot
geposted Wed 14 May 14 @ 7:02 am
aaa yes i have found it but its not what i was expecting everything is so small :) with no documentation on the plugin and how it can be used. Will wait till SBDJ can give some more information.
geposted Wed 14 May 14 @ 7:08 am
You click the little cog icon and the GUI opens. The GUI presented should be that of a 'traditional' equaliser?
Are you on a retina Mac?
geposted Wed 14 May 14 @ 8:01 am
Hi SBDJ
no i am not on a mac just windows 8.1 anyway i have found it using a different skin from the plugins skin section. Also by using the graphic can you still use the EQ knobs on the hercules rmx without it affecting the Graphic Equaliser
geposted Thu 15 May 14 @ 2:42 am
