Topic: Custom Buttons
I created a custom button that loops out the song that's playing. The string is: effect_active "LoopOut.
I would like to add to it to play the song in the other deck.
geposted Wed 14 May 14 @ 8:19 am
I tried automix but the fader moves too fast. I'd like the fader to remain in the center. I'm looking for a simple way to loop out of one song and play the next song smoothly.
geposted Wed 14 May 14 @ 9:48 am
Buried on page 21 with not one reply. If I complained about something I'd have gotten many responses.
geposted Sun 18 May 14 @ 12:22 am
I don't really know what you want to achieve if the crossfader shouldn't be moved.
If you just want to loop out and play the other deck, use this script:
effect_active "LoopOut" & device_side 'left' ? deck right play : deck left play
If you need more help, please give more information.
Regards,
Daniel
geposted Tue 22 Sep 15 @ 1:14 pm
what button shall i use to fade out the sound and play the other?
geposted Tue 06 Oct 15 @ 3:51 pm
A left custom to play the right deck, a right custom to play the left.
geposted Tue 06 Oct 15 @ 7:22 pm
speng1PRO InfinityMember since 2010
1
geposted Mon 02 Nov 15 @ 8:37 pm
