Topic: database for v7 / v8
Okay about the database. If I analyze a new folder/ files and v7. Will v8 automatically read new information or will I need to analyze it again v8. If it should read it what settings do I need to make?
geposted Wed 14 May 14 @ 12:04 pm
8 only reads the 7 database when you first install it.
Changing the data in either database will not change it in the other.
If you delete the 8 database after modifying something in 7 then 8 should reread it.
geposted Wed 14 May 14 @ 12:09 pm
jaakkoPRO InfinityMember since 2006
It does not work. Anyway, there is almost nothing in the new VirtualDJ/database.xml. If I altern a tag in VDJ 8, where the change is saved? It is not in the old VDJ 7 database, it's not in the new database.xml? I even try to do a search in files to find the text I put in a tag. There is no place where it is saved, still VDJ8 somehow reads it somewhere. Btw I use win 8.1 if it matters.
geposted Sun 18 May 14 @ 4:58 am
...... (duplicate message please delete this)
geposted Sun 18 May 14 @ 5:00 am
