Topic: mappers MC6000
djmilaPRO InfinityMember since 2008
How to adjust for changing effects.
Now it is only the first and last effect.Nothing in between.
I turn the knob smoothly, but does not respond. Only min a max ( two FX :first in the list and the last in the list)
geposted Wed 14 May 14 @ 2:32 pm
basxrPRO InfinityMember since 2011
Hi , push the efx button under the rotary knob . in the middle of your mixer (row of 4 btn)
then use the rotary slider/button to change the effect
try using the 'single effect' page in the gui for now
a more intuitive mc6000 mapper is on it's way
geposted Wed 14 May 14 @ 3:10 pm
has done the same thing as VDJ7.X
changes only two or tree effect in list
how to work others users with mc6000 ( how changes EX in denon )
geposted Wed 14 May 14 @ 3:30 pm
