Hi guys enjoying playing with the new software.
I,ve noticed that when you right click on saved playlist the option is no longer present to merge into playlist as it is in vdj7.
Any chance this could be added in some fashion. IE: merge into Sidelist / Automix.
Thanks Guys keep up the good work it's coming along nicely
geposted Wed 14 May 14 @ 5:54 pm
anyone else noticed this
geposted Fri 16 May 14 @ 1:01 pm
Yes! Its not just MAC. I have a PC. The alternative is that you can drag and drop songs directly into a playlist in the browser window. But it gets added to the bottom of the list (merge playlist kept new songs at the top). So you can select a song and drag it to the left and drop it into the playlist of your choice.
I agree they should bring back the merge playlist option. Also I think the drag and drop should add songs to the top of the list rather than the bottom. Surely, you would always want new songs at the top?
Hope someone sees this!
geposted Sun 18 May 14 @ 9:16 pm
