I've been experimenting with creating some new video samples tonight, and have run into a small problem. I load a video clip to an empty pad, then open the sample editor, from there I can move the blue lines on the waveform to select the start and end points for the sample. Once I've saved it, it plays as it should from the pad. However, if I then re-open it in the sample editor to fine-tune the in/out point a bit, the blue markers have gone, and all I can do is delete the pad and start again from scratch. Is this something that could be improved in future?
geposted Wed 14 May 14 @ 6:11 pm
BUMP
This issue is still present. The dark blue in/out markers do not always appear.
They're pretty hard to spot in the first place - being so dark, thin and tucked away in the corners, but sometimes they don't show up at all.
How are people supposed to edit their sample in/out points?
geposted Sun 03 Aug 14 @ 5:55 am
Same thing here..........
geposted Mon 04 Aug 14 @ 7:12 am
Same problem in POI window
geposted Mon 04 Aug 14 @ 10:40 am
+1 for this issue.
geposted Mon 02 Feb 15 @ 3:41 pm
