(I mistyped the controller name... It's the MC6000MK2.)
I've mirrored my exact settings from VDJ 7.4.1 into V8 and the control mappings (Play/Cue, etc.) work perfectly fine (as far as I can tell), however after playing the cued side in the headphone for about 5 seconds, the track continues to play, however the audio to the headphone stops. If I turn the volume up considerable on the headphone, I can hear bleed, however nothing else.
I closed out to V8 and opened up V7.4.1 and it works just fine. (I'm using a Mac and using the updated build that was released today.)
The Output is set to Chan 1&2 / Master, and Chan 3&4 Headphones and the 6000MK2 is set to the Sound Card.
Please advise.
Please advise.
geposted Wed 14 May 14 @ 10:43 pm
I'm using a Denon MC6000-2 and everything works perfectly. It was pretty much plug and play. If you have the mc6000-1, hook it back up and insure everything works then just swap controllers. Kinda archangel to do it this way but at least it will rule out that maybe some how your settings are off.
geposted Thu 15 May 14 @ 12:06 pm
MC6000 MK1 not fully good for V8 . Problems witch change FX
geposted Thu 15 May 14 @ 2:03 pm
