These are some errors that occured while trying. I mostly work with video.![](/image/59212/135377/Play gives error.and crash.PNG)
Here you have a crash screen shot. I tried to play a track on player 1 (Sabrina)as a result I got what you see. I tried numorous times to play this track and one time I got a few seconds of audio before crashing.
With this scr shot I tried to edit a video witch gave this result.
This is the result with truying the track cleaner.![](/image/92420/135380/save track edit.PNG)
This image shows that it is impossible to close the options window because the x in the top can't be reached. Only after narrowing the window you get to see the x and you can close it. It always opens this way
![](/image/1727/135381/Impossible closing options window.PNG)
The last shot is what happens after i played 2 videotracks. On the launch of the second track, my output image turned white.
![](/image/16411/135382/second track played screen turns white.PNG)
That's it for now. I must ad that I am trying to adjust in the options which could maybe explain some issues. I will try to reset on standard to see what happens.
geposted Thu 15 May 14 @ 1:58 am
I read in another tread you should install activex 9.0C. So i did and look... Several problems are solved. Sabrina comes to live!
geposted Thu 15 May 14 @ 5:36 am
