Hi Guys,
Heres a strange one, when I first start up VDJ8 using the DDJ SX everything sounds great, effects wise. After about 10 mins and then say use roll effect the sound is distorted and choppy?
Any ideas?
Note: The software has set my Asio buffer latency at 1.4ms and when I click (Standard Setting) it enters those values of 5.4ms, I click apply and come out of the options menu, when I go back in, the ASIO buffer has reset back to 1.4ms. I have tried setting this with the SX turned off, saved it as a custom setting etc.... nothing works it will not let me select a different buffer size as I presume this is whats making the audio distored after a few mins.
John
Any ideas?
John
geposted Thu 15 May 14 @ 7:39 am
I would say that's the reason. 1.4ms is very low!
6-10 is more usual.
6-10 is more usual.
geposted Thu 15 May 14 @ 7:42 am
Hi Groovin,
Yes I know - just will not let me select anything else at all, rather I can select a different value but will not let me keep that setting. It is odd though as normal playing and audio along with scratching does not suffer at all, only when effects are used.
geposted Thu 15 May 14 @ 7:45 am
maby have a look on the "ultralatency asio setting" the old default setting was 11ms or 512 frames
default is latency=automatic (wich prop. do the reset for you)
and default is ultraLatency=yes (wich will do prop. th 1,4 ms)
<performances>
<sampleRate>Automatic (44100)</sampleRate>
<latency>Automatic</latency>
<ultraLatency>no</ultraLatency>
<overclock>no</overclock>
<maxPreloadLength>15</maxPreloadLength>
<pitchQuality>2</pitchQuality>
<scratchFilterQuality>8</scratchFilterQuality>
<cpuMeter>system</cpuMeter>
<songLoadPriority>normal</songLoadPriority>
</performances>
<performances>
</performances>
geposted Thu 15 May 14 @ 7:54 am
Hi gbeul,
That's sorted it, thank you.... Latency was set to 1 not auto so that was preventing changing it.
Regards John
Regards John
geposted Thu 15 May 14 @ 11:14 am
