I have been using VDJ8 since day one and now, I opened it today and can not drag (and drop) tracks from the playlist (below) to either player.
Any suggestions?
(15" Macbook Pro, 2.6 I7, 8 Gig Ram, 1 TB Internal HD)
Any suggestions?
geposted Thu 15 May 14 @ 9:56 am
Try opening up your options, search for "ShowCoverForDragDrop" and set that to "Yes". See if that resolves it. The problem with VDJ 8 is that if this option is turned off, there is no visual feedback when you are dragging a song from the playlist, so even though you are dragging the song, it seems like nothing is happening. Hope this solves your issue.
geposted Thu 15 May 14 @ 10:38 am
I will try it...
geposted Thu 15 May 14 @ 12:05 pm
did your config window end up behind the skin?
geposted Thu 15 May 14 @ 12:42 pm
