I've been using my VCI-380 for small gigs since it's very compact and not as cumbersome as my NS6 (which I absolutely love overall). Virtual DJ7 was really bad with the 380 and now I don't see any improvement with VDJ 8.. this is really sad as this is a great controller that I'd love to see better supported. Has anyone found workarounds to the scratching, sound quality, etc. ?
As for VDJ 8 itself... great software I'm still working through all the features and trying to find bugs, but so far so good! My NS6 works flawlessly with it and I was able to get such better scratching sounds and overall sound that it's made me one happy customer. Now if I can fix it for the VCI-380...
geposted Thu 15 May 14 @ 10:55 am
Any help? Suggestions?
geposted Fri 16 May 14 @ 4:45 pm
You mentioned both scratching and sound quality. Are those 2 related ? I mean it sounds bad when u scratch or even without ?
Are you on Mac or Windows ?
geposted Fri 16 May 14 @ 5:54 pm
im having scratch issues too...using the 380.
my problem is the song moves forward no matter what...if i do a simple back and forth motion...eventually the song is no longer where i started the scratch...this is a problem new to V8 because V7 didnt have this issue neither does serato.
geposted Sat 17 May 14 @ 2:39 pm
Yeah the overall responsiveness is terrible and so the sound quality and scratching gets affected. When I plug in the NS6, it works 100% flawless and sound quality is high.
For the VCI-380 when I use Serato DJ it works perfect and runs flawless... so I know there is some type of issue in terms of how it is being used by VDJ. Just wanted to see if you guys have tested this on your end.
Using Windows. My laptop is an i5, 8gb of memory, samsung ssd and it's always been pretty amazing for performance.
geposted Sat 17 May 14 @ 11:57 pm
Nevermind! I downloaded the latest Vestax ASIO driver for the VCI-380 and now it works flawlessly.
For anyone looking for it, it's here: http://help.vestax.co.jp/en/detail.php?id=450&id_page_url=387
geposted Sun 18 May 14 @ 12:11 am
Something that I think need to be fixed in the new default mapper:
1) Deck 1 HotCue PADs are now colored in RED and BLUE on Deck 2, inverted respect VDJ 7 mapper and default VDJ skin colors, that are Blue on left and Red on right Deck.
2) Another strange think of the mapper is related to vumeters, that now flash up and down when I move the volume faders (if is an intended function I think it could only creates confusion).
Reported - Thanks [Babis]
geposted Sun 18 May 14 @ 1:33 pm
There is an error in the mapping for the pad colours for decks 1 & 2 in hotcue mode. This will be fixed.
The VCI-380 VU meters are controlled by the firmware when using the VCI-380's built-in sound card. They can also be controlled by MIDI, but this causes conflicts if the VCI-380 sound card is in use. LED_VOLUME wasn't mapped by default, but was default linked in the definition to VOLUME. This link will be removed.
geposted Wed 21 May 14 @ 7:48 pm
Hi everyone. I recently purchased a VCI380, and in the past week Vestax has taken down their website. I am tyring to find a download for the VCI380 Audio driver, but all of the websites i have searched on google redirect to the Vestax support website (which no longer is active). --Does anybody have a copy/file/zip of the audio driver file for the VCI380? I am using Windows 7 64 bit. I would be extremely grateful if someone could find this file for me! Thanks for your help. I am really happy to using be my Vestax unit.
geposted Tue 02 Dec 14 @ 12:26 am
Try here.. https://web.archive.org/web/20141022043327/http://help.vestax.co.jp/en/catagoly.php?parent_id=4
(If not working, copy paste the link to your browser)
geposted Tue 02 Dec 14 @ 2:11 pm
Hi All, i know its old thread, but just wondering has anyone got a copy of the vci380 latest driver the one that works with vdj8
All im getting is really poor sound, if i flip back to vdj7 it works fine.
It would be a great help as ive paid for vdj8 and cant use it.
Many thanks in advance
geposted Wed 23 Nov 16 @ 6:38 pm
